Sum a custom result -
I have a viscoplastic material, subject to a nodal force over the period of one second.  I have set a custom result to calculate the strain energy at each node for each time step through the whole time that the simulation is to be run.  However, I would like to sum the strain energy across all the nodes at each time step iteration.
Currently, I have to inspect the results at each node and ouput each time step (can be 20 or so) and manually add the results, which is quite time consuming, as you can imagine.  I cannot for the life of me find out where my output files are going, which I think is the answer, but I am at my wits end.
Thank you for any direction you can give. It won't let me attach my .fem file
AstroJohnPE
Hi zangrilli.1,
I understand your steps in general, but how are you creating the output files?
A better question would be "is there some way to output the sum of the results for selected nodes for all time steps" so that you do not need to do all of the "manual" work. The answer is probably yes. (I know that this works for other results, but I'm not sure for custom results.) These steps are from memory, so the wording may be off a bit.
  1. select the nodes that you want to sum.
  2. right-click in the graphics area > Edit New Graph.
  3. If the default is not "Sum", change it to sum.
  4. The graph should show the sum of the result versus time. Right-click the graph and choose "Export".
  5. The Export dialog has an option to export the data to the clipboard or a text file.
Good luck.
Thank you thank you thank you! Worked like a charm AstroJohnPE and from memory too.  🙂
All the best and Happy Halloween
