- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a viscoplastic material, subject to a nodal force over the period of one second. I have set a custom result to calculate the strain energy at each node for each time step through the whole time that the simulation is to be run. However, I would like to sum the strain energy across all the nodes at each time step iteration.
Currently, I have to inspect the results at each node and ouput each time step (can be 20 or so) and manually add the results, which is quite time consuming, as you can imagine. I cannot for the life of me find out where my output files are going, which I think is the answer, but I am at my wits end.
Thank you for any direction you can give. It won't let me attach my .fem file
