Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Strange meshes
1 REPLY 1
mechamania
589 Views, 1 Reply
Strange meshes
Hi
I have a assembly with a very strange meshing result.
See the picture below.
There are two identical tubes at the front of the assembly. The left tube is meshed OK. The right one is a mess.
I'm meshing the tubes using solid meshing of type Bricks and Wedges (Layered mesh of thin parts).
When I use the Midplane meshing, the right tubes almost disappears. See picture below
The tubes are identical (extruded from one sketch in Inventor). Any idea what could be wrong??
1 REPLY 1
mechamania
in reply to: mechamania
Found the problem.
Somebody told me the problem could be that I extrude both tunes into one part.
When I make two separate parts for the two tubes, all is ok.
