Simulation Mechanical
Hello
Do you know how I can aply a load in a specific point?
John_Holtz
Autodesk Support
Autodesk Support
I know how to do that. Smiley Happy
  1. Select the node. ("Selection > Select > Vertices")
  2. Choose the type of load to apply. ("Setup > Loads")
Perhaps you are working on a CAD model and are really asking "how to create a node at a specific location so that I can apply a load". To do this, see the page "Construction Vertices - Seed Points" in the User's Guide.
Let us know if you have any other questions. Be sure to provide as much specific information as possible (type of analysis, type of load, what you are trying to do, and so on).
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
