Simulation Mechanical 2016 Unhandled Exception
Hello Experts,
one of our colleague has a problem with the "Autodesk Simulation Mechanical 2016".
He can start the program but if he tries the actual analysis he is getting the following error:ErrorErrorDetailed ErrorDetailed Error
I also included a dumpdata (https://ufile.io/xklhw)
I tried to reinstall the whole program (with the inbuilt reinstall function and with a clean reinstall).
Both times it was unsuccessful.
I would kindy ask for your help and would appreciate hearing from you.
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Sorry to read about the crash. I think the problem is that the Simulation Job Manager (SJM) is crashing. There should be an article on the Autodesk Knowledge Network that discusses this issue.
Try this article to start: https://knowledge.autodesk.com/support/simulation-mechanical/troubleshooting/caas/sfdcarticles/sfdcarticles/Simulation-Mechanical-crashes-when-analysis-is-started.html?st=simulation%20job%20manager%20crash
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
