Run from Command Line
Hello Everyone,
I am having this problem as well:
http://forums.autodesk.com/t5/simulation-mechanical-and/problem-of-unknown-error-error-1/m-p/5139218...
But the thing is, where does one find information on how to run the simulation through the command line?
Thanks!
AstroJohnPE
Hi scudelari,
I like to create a batch file (.BAT) to run the model or models from a command line. The batch file essentially becomes my “documentation” so that I can find the information whenever I need it. These commands can be entered individually in a command window, too. (Type “CMD” in the Windows “Start > Search programs and files” search bar.)
The overall steps are as follows:
  1. Do a Check Model whenever you are ready to do the analysis. “Analysis > Analysis > Check Model”.
  2. You may need to exit the software before you try to run the analysis from the command line or batch file. I did not test this step.
  3. View any folder with Windows Explorer.
  4. Create a batch file (right-click > New > Text Document) and change the filename AND extension (to .BAT). Note that you may need to set the “Tools > Folder Options > View” to display the file extensions; that is, uncheck “Hide extensions for known file types”. (If the .TXT extension is now shown when you create the new text document, then your extensions are hidden.)
  5. Right-click the batch file and choose “Edit”. Copy or type in the text of the batch file given below.
  6. You need to change the drive designations K: and J: to a drive that is not already in use.
  7. You need to change the path "C:\Program Files\Autodesk\Simulation 2014" to the location where your software is installed.
  8. You need to change the ‘folder with the model’ to the location of your model. “my model” is the name of the .FEM file that you normally open, and “.ds_data\5” is the design scenario that you want to analyze. (The design scenario folder contains the file “DS.ASD” that the processor reads.)
  9. You need to change the processor name “pppp” to the appropriate name. The list below is from the Help.
  10. There are various runtime options which you can see by entering “K:\pppp.exe -help” in a command window.
Contents of the batch file (copy or type this text)
  :: use a drive substitution for the folder with the ADSK Sim Mech software
subst K: /d
subst K: "C:\Program Files\Autodesk\Simulation 2014"
  :: use a drive substitution for the folder with the model
subst J: /d
subst J: "C:\Simulations\junk nf.ds_data\4"
  :: run the analysis
K:\ssap1.exe "J:\ds" -run
pause
List of processors
  • Linear static stress: ssap0 filename -run
  • Natural frequency (modal): ssap1 filename -run
  • Transient stress (modal superposition): ssap2 filename -run
  • Response spectrum (modal superposition): ssap3 filename -run
  • Transient stress (direct integration): ssap4 filename -run
  • Frequency response (modal superposition): ssap5 filename -run
  • Critical buckling load: ssap6s filename -run
  • Random vibration (modal superposition): ssap7 filename -run
  • Natural frequency (modal) with load stiffening: ssap8s filename -run
  • Weight and center of gravity: ssap9 filename -run
  • Static stress with nonlinear materials, MES with linear materials, MES with nonlinear materials, and MES Riks Analysis: apak4 filename -run
  • Steady-state heat transfer: ssap10 filename -run
  • Transient heat transfer ssap11 filename -run
  • Electrostatic: esap filename –run
I piece these instructions together from these pages in the Help:
  • Perform Analyses - Run Simulation
  • Schedule Analyses
This should go directly to an autodesk Support Knowledge Base Solution or they should do a video explaining how to do it.
Thank you John i was doing a MES thermal stress analysis and this help to solve the problem of  2015 R1
zhuangs
To run a model from command line, if you want to have all the running information in the log file, not on the CMD screen, you can add "-silent".  To take MES as an example, you can input
\arun4 ds -run -silent
In this case, all the iterative information will be output into the ds.alg file for MES, rather than on the CMD screen.
-Shoubing
Thank you so much.
You are the best!
