Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
Results visualization problem
2 REPLIES 2
iegia
522 Views, 2 Replies
Hello
I am a new autodesk simulation mechanical user.
I am using Autodesk Simulation Mechanical 2015 R1
I am having some problem with the results visualization. I want to show "shaded with mesh" visual style but I don´t get it. I can´t either see the reactions. I am following steps tutorial. Is there any problem with this release?
Thanks in advance
2 REPLIES 2
iegia
in reply to: iegia
Hello
I have been talking with my Autodesk distributor, and we have fixed the problem. The post-processor doesn´t work, there was a problem with and old Autodesk Revit 2012 windows registry.
I post the solution if it can help someone.
Andrew.Sartorelli
in reply to: iegia
Hi iegia,
Glad to hear everything is working for you now! Based on your description, I believe the following was the solution your distributor/reseller likely provided you 🙂
Using the registry editor (RegEdit.exe) modify the conflicting registry key:
  1. Open RegEdit.exe
  2. Locate the key at HKEY_CLASSES_ROOT\TypeLib\{CCD8C5EB-3980-11D0-A37A-00805FCA87EB}\1.0\0\win64
  3. If the registry key points to "C:\\Program Files\\Autodesk\\Revit Structure 2012\\Program\\RevitDB.dll" then rename win64 to no-win64
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
