- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello!
I am having trouble with my mesh when I try to use a Rhino model. I want to design a barge with all it's structure with plate elements. The problem is, my hull is not getting attached to the structure.
When I have a surface with its edge touching another surface, I would like Simulation Mechanical to understand that I have these two surfaces welded. Therefore, It is necessary that the mesh creator generates common nodes on those two surfaces. The meshing is not connecting when a surface reaches the other. An example of it is shown on the following images:
Image 1: Rhino model
Image 2: Meshed model showing meshing problems
Could anyone give me any help?
Thanks in advance
Yossef Sami El Didi
