non-linear residual of 1.00
JohnBeach
Message 1 of 10
JohnBeach
I have a model that runs in static linear. It will not run in static non-linear. It simply runs through the 19 time steps and constantly returns a residual convergence of 1.
Can a developer or Autodesk person have a look at it and see what I have overlooked? I have successfully changed the analysis type on a smaller model before.
I copied across to a new design scenario.
changed all plates to shells
changed element definitions
re-assigned material to be sure
re-assigned pressure load
re-assigned constraints
check analysis parameters and added a load curve
I tried to attach and ach file; but it was 11 MB. To whom would I send that file?
Assistance appreciated,
John
Replies (9)
Message 2 of 10
AstroJohnPE
Hi John,
One suggestion is to set the load curve(s) magnitudes to 0 so that there is no load on the first time step.
  • If this solves, then it may be that the initial load is too large.
  • If this does not solve, my guess is that something in the model is statically unstable.
  1. Are all of the parts connected node-to-node? (Linear stress has "smart bonding' which connects parts even if the nodes do not match; MES does not have this capability.)
  2. The only other thought that comes to mind is the solver that is used. Either the log file or summary file (accessible from the Report tab) indicate which solver was used, such as the iterative solver or sparse solver.
Otherwise, did you try the tips in this post to reduce the size of the archive? http://forums.autodesk.com/t5/Autodesk-Simulation-Mechanical/Create-Post-or-Provide-an-Archive-of-yo... Maybe you can get is small enough to post.
Message 3 of 10
zhuangs
Hi John,
You can send the model to me: Shoubing.Zhuang@autodesk.com, better via Accellion
I can help take a look at the model.
-Shoubing
Message 4 of 10
JohnBeach
Thanks Shoubing. I have emailed file.
Also here is link to ach which I think works.
https://dl.dropboxusercontent.com/u/42633891/1926-CA-0211%20A.ach
Message 5 of 10
zhuangs
Hi John,
If you can change the "Element Formulation" in "Advanced" Tab of Elment Definition of the 5 Parts (1~5) from "General" to "Thin", the model will run to completion smoothly.
The 5 Parts (1~5) have the other dimensions much larger than the thickness, so "Thin" shell will be appropriate for them.
-Shoubing
Message 6 of 10
JohnBeach
Thank you for suggestions.
Manually setting the solver to sparse (it was automatically going to iterative AMG) allowed it to solve in 20 time steps and 1.5 hours.
Setting the element formulation to thin allowed it to run; but at 25% started reducing time steps to solve so I stopped it.
I guess I will try thin and sparse.
I would have thought it would automaticallly try sparse if iterative did not work. I would appreciate comments.
Message 7 of 10
JohnBeach
The thin and sparse idea made it to tie step 9 of 20. IS this a problem with the thin elements perhaps?
Message 8 of 10
zhuangs
Within their capabilities, "Sparse" solver and "AMG" solver should provide similar results.  However, "Sparse" solver usually works for small or medium models, while "AMG" solver works for large model.
Once "Automatic" option is defined, the code will automatically select one of them based on the size of equation.
-Shoubing
Message 9 of 10
JohnBeach
I have this problem again. I am applying a hyrdostatic pressure and it looks like the solver does not recognize the pressure. I put a simple force on it and it does run.
Message 10 of 10
zhuangs
Hi John,
Copying a design scenario (Linear) to another one (Nonlinear), we do need to click the "Element Definition" for all the parts, since Nonlinear and Linear use different AGSDB variables, defined by UI.  You did right.
To use "Static Nonlinear with Nonlinear Material Models" analysis type, the model must be static stable and well constrained to avoid any rigid body motion.  For your model with shells, the model should not move along x-, y-, and z- directions, and not rotate along Rx-, Ry, and Rz.  Otherwise, the model generally cannot converge with "Static Nonlinear with Nonlinear Material Models" analysis type.
If you think the model is well setup, you can try "MES with Nonlinear Material Model" and see this can help.
You can send the model to me via email.
-Shoubing
