Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Moving-load dynamic problems
lihouxin065
lihouxin065
can anyone help me ?
can this problem be solved with MES(Mechanical Event Simulations)?
how to setup the problem?
lihouxin065
Vibration of a beam excited by a moving mass
John_Holtz
Autodesk Support
Autodesk Support
Hi @lihouxin065
There are two options that I can think of.
  1. You model the mass m and use a prescribe displacement to move it across the bridge.
  2. You apply N nodal forces along the length of the bridge and use a different load curve for each force. The load curve increases and decreases the load as a function of time to simulate the motion of the moving mass.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
lihouxin065
Thank you so much.
