Model stability
Model stability
john_erichsen
Model stability
john_erichsen
I have a steel model that has two clamp assemblies that in contact with a pipe.   The clamp assemblies are held to the pipe by bolt pretension.   I am running static stress with linear material models.   The contact surfaces are set as surface with friction.   I have added 3d springs to the contact surfaces to stabilize the model.   However, I continue to get a "warning: quasi-periodic solution achieved" which I have interpreted to represent a model result that is incomplete.   If I continue to raise the stiffness of the 3-D springs, at what point do the springs begin to influence the results?   How do I review the model to understand the impact of the higher spring constant?  I have reviewed the deflected shape to confirm the results make sense, however, this seems to be less than an exact approach.
Thank you
AstroJohnPE
Hi John,
You may want to try a different "Setup > Model Setup > Parameters > Contact > Iteration Method" (or something like that) to see if that avoids the periodic solution.
My approach is to check the force in the springs ("Results Contours > Other Results > Element Forces > Axial Force"). If the axial force is too high, you need to reduce the stiffness.
john_erichsen
I have been using sparse. Is iterative better?
The same warning occurs with a very large stiffness.
So it is the solver or a modeling issue I have not discovered. Thanks
Sent from my iPhone
Thank you
John R Erichsen
10321 Adams Rd
Granger, IN 46530
574-277-0670 x701
AstroJohnPE
Hi John,
I think the choice between the sparse and iterative solver does not have an effect on the quasi-periodic result that you are getting with the gap/contact elements. The sparse versus iterative solver relates to how the system of equations is solved. The contact iterative method that I mentioned before is related to how the algorithm adjusts which nodes are in contact and which are not in contact depending on the previous solution. The quasi-periodic result indicates that the same set of nodes were found to be in contact during two different contact iterations, or in other words, the algorithm is in a repeating loop.
But in general, I let the software choose which solver -- sparse or iterative -- to use.
