Model stability
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a steel model that has two clamp assemblies that in contact with a pipe. The clamp assemblies are held to the pipe by bolt pretension. I am running static stress with linear material models. The contact surfaces are set as surface with friction. I have added 3d springs to the contact surfaces to stabilize the model. However, I continue to get a "warning: quasi-periodic solution achieved" which I have interpreted to represent a model result that is incomplete. If I continue to raise the stiffness of the 3-D springs, at what point do the springs begin to influence the results? How do I review the model to understand the impact of the higher spring constant? I have reviewed the deflected shape to confirm the results make sense, however, this seems to be less than an exact approach.
Thank you
