Message 1 of 9
05:34 AM
Hi guys,
i have a common question. I created a curved beam with a gear on it in Inventor ´15 Pro. I want let slide the gear above the curved beam and let the programm calculate the bend of the beam and the reaction forces.
I want to calculate it with an "linear static" analyse-method. My problem is: How can i tell the programm, that i want (for an excample 10) points of contact between the gear and the beam and calculate there my solution? In MES-Analysis method i can make it with time steps, but how can i make different load steps on different points of the beam in static linear?
Here is my problem from the first place (actually in german)
Thank you a lot!
Greetings Tomatello
