Simulation Mechanical Forums (Read-Only)
Welcome to Autodesk’s Simulation Mechanical Forums. Share your knowledge, ask questions, and explore popular Simulation Mechanical topics.
415 Views, 1 Reply
hola a todos
buenas tardes. estoy en el proces de reinstalacion de licencias de Autodesk, sin embargo, me dice que hay un error y que no puede continuar con el proceso, que necesita atencion
1 REPLY 1
John_Holtz
Hi @Anonymous
You should post your message to the Suscripciones, Instalaciones y Licenciamiento - Español forum.
  • Be sure to include images of the exact error message.
  • Please include the exact steps that were being performed when the problem occurred.
  • Please indicate the software being installed or licensed and the version.
=== translate.google.com, my reply ===
Debes publicar tu mensaje en el foro Suscripciones, Instalaciones y Licenciamiento - Español.
  • Asegúrese de incluir imágenes del mensaje de error exacto.
  • Incluya los pasos exactos que se estaban realizando cuando ocurrió el problema.
  • Indique el software que se está instalando o con licencia y la versión.
=== translate.google.com, original post ===
Hi all. Good afternoon. I am in the process of reinstalling Autodesk licenses, however, it tells me that there is an error and that it cannot continue with the process, which needs attention.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
