Fusion 360 Modal Analysis solver error
grigore.andrei1234
grigore.andrei1234
Hello!
I am trying to run a modal analysis of a pump shaft together with the rotors and magnetic drive coupling. In all, there are 7 components present in the simulation.
After setting up my simulation and running it on the cloud, it runs for about 30 minutes showing progress and then i get the following error:
Mesh Details:
Error: Solver Error
Error: An error occurred while solving the model.
Job has finished with errors. The Cloud Credits for this job will be refunded. Receiving results.
1846967 Tetrahedra : 100.0% of elements (100.0% of volume)
Face Angle min: 3.67, max : 172
Dihedral Angle min: 1.12, max : 178
Worst shape ratio : 96.7 on element 1256465
Worst aspect ratio : 12.6 on element 176700, shortest edge: 1.8e-05, longest : 0.00469
Lowest collapse ratio : 0.0128 on element 1256465
Worst Jacobian ratio : 3.63 on element 175711
Error: 8
Error: Solver Error
Error: Solver Error
The model is attached in the following link:
https://a360.co/3rvAozi
What is the reason for this error?
I searched the forums and the only proposed solution i could find was to reinstall the software, which i already did but did not solve the issue.
Thank you in advance!
mcmillr
Hi Andrei, sorry you have having this issue. I would like to look into this but I am not able to access that link. Could you share a public link or export a fusion archive and attach it?
Thanks!
Rob McMillan
Software Architect, Fusion Simulation
John_Holtz
Autodesk Support
Autodesk Support
Hi @grigore.andrei1234
I suggest that you look at the output file to see the full text of the solve error. Right-click on "Results" in the browser, then "Solver Data > Solver Output". There should be an error number, such as E5004, which indicates what the problem is. You may need to use articles from knowledge.autodesk.com written for Inventor Nastran to decipher what the error number means.
Then you should post your questions and model to the Fusion forum. Simulation Mechanical is a different program and most readers here will be unfamiliar with Fusion.
John.
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
grigore.andrei1234
Yes, i forgot to make it public. Here it is:
https://a360.co/3G97pWg
grigore.andrei1234
Oh, i did not know this. I will post this to the Fusion forum as well.
Thanks!
