Show only
Search instead for
I have to do this static stress analysis of a corkscrew, but i´m having this problem simulating the gears, the simulation doesn´t run when it put there more than one part.
We will be glad to provide some help. I suggest the following approach:
attach a few images to show what you are analyzing and what you have tried.
indicate when the problem occurs (during meshing, during analysis, some other time) and what the error is (either images if a dialog is given, or text if it is an error in a log-type file.)
attach an archive of the model so that someone can dig into the problem if necessary. (From the app button (top left corner), "Archive > Create > Model Only" and attach the resulting .ACH file. See also "Create, Post, or Provide an Archive of your model" if you have any problems with the archive.)
John Holtz, P.E. Global Product Support Autodesk, Inc.
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
