Cannot change element type to 2-D, option missing
Just wanted to do a simple 2-D analysis but cannot change it to 2-D type (could before...)
My model is very simple also in the attachment if you want to see.
What i did is:
1. Start a new analysis
2. Use the sketch option to put 4 (2 for each part) circles in one plane
3. 2-D mesh both parts
4. Trying to select element type 2-D and its missing (usually it is selected by default)
Am I doing something wrong or I'm missing something ?
Hmm, I'm guessing you cannot start from the XY plane ?
Andrew.Sartorelli
Hi @Anonymous,
In order to use 2D elements, your drawing should be on the YZ plane at X=0. If you're importing a model in DWG form, there should be an option to transform the geometry to a specific plane. We do have a tip in the 2D element help page of how to transform your drawing if you accidentally drawn in the wrong plane.
Tip: Useful commands for converting 3D models to 2D models are Draw Pattern Relocate & Scale, Draw Pattern Rotate or Copy, and Draw Modify Project to Plane. For example, you may accidentally create a mesh in the XY plane. You can rotate the mesh to the YZ plane using either the Relocate & Scale or Rotate command. Due to round-off, some nodes may have a small X coordinate value that prevents the element type from being set to 2D. In this case, use Project to Plane to snap the nodes exactly to the YZ plane.
Andrew
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Andrew Sartorelli - Autodesk GmbH
