Autodesk simulation mechanical 2018.1
RansiDevendra6239
Message 1 of 8
RansiDevendra6239
Hello everyone,
Can someone advise me how to install Autodesk simulation mechanical 2018.1? I have already 2018 installed on my computer.
I look forward to hearing from you soon.
Thank you.
Best regards,
Ransi
Replies (7)
Message 2 of 8
John_Holtz
Autodesk Support
Autodesk Support
Hi Ransi,
See this post for the update file: Sim Mech 2018.1
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Message 3 of 8
RansiDevendra6239
Hi John,
The instructions given to install update 2018-1 is not clear. When I open Autodesk desktop app the window is as shown in the attachment.
Please advise.
Thank you.
Best regards
Ransi
Message 4 of 8
John_Holtz
Autodesk Support
Autodesk Support
Hi @RansiDevendra6239
Why are you trying to use the Autodesk App? The installation file for Sim Mech 2018.1 is attached to the post that I referenced. All you need to do is download the file, unzip it, and run the installer (the file "Simulation_Mechanical_2018.1_Update.msp").
John Holtz, P.E.
Autodesk, Inc.
Message 5 of 8
John_Holtz
Autodesk Support
Autodesk Support
I wanted to make sure you were able to access the 2018.1 update and get it installed.
John Holtz, P.E.
Autodesk, Inc.
Message 6 of 8
RansiDevendra6239
Hi John,
To run the installer (Simulation_Mechanical_2018.1_Update.msp) is it ok if I right click and click on apply and then continue? See attached.
Thank you.
Best regards,
Ransi
Message 7 of 8
John_Holtz
Autodesk Support
Autodesk Support
Hi Ransi,
Yes, it looks like "Apply" is the correct option in this situation.
John Holtz, P.E.
Autodesk, Inc.
Message 8 of 8
RansiDevendra6239
Hi John,
Thank you for the advice. I managed to run the update.  When I check "About Autodesk Simulation Mechanical (64-bit)" it shows "Build 2018.01.0053 01-Oct-2017. I believe the installation had taken place correctly?
Thank you.
Best regards,
Ransi
