Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Solid section
4 REPLIES 4
788 Views, 4 Replies
Solid section
Hello everyone,
in showcase when I cut a solid it appears hollow and transparent... I want section plane to be solid, is it possible?
4 REPLIES 4
MarionLandry
Unfortunatly, this is the way it looks in Showcase. If you want a solid cut, you might want to consider cutting your model in Inventor and/or Revit first and import two models. One cut and one not cut. Then, you can use the visibility alternative lineup to display which one you want in your presentation.
Good luck
Marion
Marion Landry
Technical Marketing Manager
3ds Max Design + Showcase
Twitter @MarionLandry
YouTube Channel @LandryMarion
https://www.facebook.com/Autodesk3dsMax
https://www.facebook.com/Autodesk.Showcase
http://www.linkedin.com/pub/marion-landry/4/a78/258
freesbee
...quite necessary feature for the future...
Massimo Frison
CAD R&D // PDM Admin · Hekuma GmbH
cikho
a possible work around could be to import the model in 3ds max and use the combined modifiers slice and cap holes
http://www.youtube.com/watch?v=ydp-KI0aKco
convert everything to edit poly, select the face created with the cap holes (should be a single one), and detach it from the original mesh.
export such face to fbx and import in showcase.
this will make you have less polygons in your scene compared to importing an entire cut model, and you don't have to apply materials twice.
if you are worried about 3ds max compatibility with your model, you can partially export your showcase scene in fbx forma and use the exported model into 3ds max.
the only disadvantage, is that you actually need 3ds max 😕
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
freesbee
...actually we have found that video during our searches. We just didn't want to roll out Max on all our machines "just" for that simple necessity (we have anyway 3dsMax in all our licenses).
We have just begun our activities with ShowCase and since our typical product is merely mechanic, we will need those cross sections almost in each of our presentations. Probably in the future there will be some room also for 3dsMax (we need to show some particles effects, like the "sand-man" from Spiderman) but won't be tomorrow for sure.
Right now we'll try to get the best possible result from ShowCase, investing those 20 minutes making the cut model in Inventor (for us it's faster than installing + maintaining + training on Max), while hoping that Autodesk will fix the behavior with the 2015.... I should write it in the "idea"... I'm just too lazy...
...thanks for the tip, anyway 😉
Massimo Frison
Technology Administrators
