Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
Showcase and AutoCAD Revolved objects ..
12 REPLIES 12
Message 1 of 13
drjohn
748 Views, 12 Replies
Showcase doesn't like revolved solids, huh?
Made a scene and applied materials and zoomed back to look at the scene and saw an anololy and zoomed into that.  A plubing device had distortred completely.  It seems as though it "revolved" it around an axix that was 90 degrees off of the original axis.
Made a few revolved solids alone to test and sure enough, all the revolved solids were corrupt. Replaced it with a cylinder solid (not the actual shape of the object) and all went well after that.
I would think that showcase would support ACAD native entities but maybe not.
Any thoughts on why this happens or has anyone else experienced this?
DJ
[edit]
I can upload the model of the offending entity if anyone (AutoDESK?) wants to have a look at the bad revolved solid so they can play with it. Have to be this evening (Pacific) when I get home from work.
[/edit]
12 REPLIES 12
Message 2 of 13
admaiora
in reply to: drjohn
Hi John,
can you attach the file?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 13
drjohn
in reply to: admaiora
@admaiora wrote:
Hi John,
I will be able to attach file tomorrow (this evening after 5 Pacific).  It's at home and I am at work right now.
Thanx for taking an interest.
DJ
Message 4 of 13
cikho
in reply to: drjohn
do you have conversion options autocad side?
like, for example, transforming the revoleve feature into a different polyset or sort of..
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
Message 5 of 13
drjohn
in reply to: cikho
I tried changing the revolved surface to regions and/or faces and that did not help much if at all.
The only way I was able to get the object with revolved surface into SC was by re-creating it as a cylinder.
Originally the object was shaped somewhat like a barrel.  In fact exactly like a barrel or keg.
I am simply opening a DWG file with SC, don't know of any other conversion prog.  Is there?
Posting file tomorrow or late this eve.
Thanx
DJ
Message 6 of 13
admaiora
in reply to: drjohn
Normally there are not problems with AutoCAD revolved solids imported in Showcase.
Admaiora
Message 7 of 13
drjohn
As I post this I am thinking that there may be a file version issue.  The ACAD model was made with ACAD 2012 and I am trying out Showcase 2014 amd I think that crosses the DWG format line. Smiley Mad
This is what I got importing the file:
This is a sample of making the revolved surface a cylinder as a workaround:
The dwg file should be attached to this post. Sometimes it doesn't work so I'll repost if it doesn't.
Thank you for taking time to look at this. Appreciate it.
John
Message 8 of 13
cikho
in reply to: drjohn
no issues for me with the dwg you posted..
i'm using showcase 2013 SP4..
maybe you have to install some hotfix for sc2014.. i know there's a problem with the fbx converter
Message 9 of 13
admaiora
in reply to: drjohn
Hi Dr John,
i have your issue with Showcase 2014 and 2015, and probably as you predict is due both to the version files and the particular change of curvature.
You can export in Autocad in FBX format then import in Showcase, you should have no problem.
Admaiora
Message 10 of 13
drjohn
@admaiora wrote:
Hi Dr John,
I will try that this eve and get back to you.
TYVM
DJ
Message 11 of 13
drjohn
in reply to: drjohn
OK ... this is starting to suck.  Smiley Mad
The same file as posted above with 2012 ACAD fbx export = nothing to export ... can only export solids.  Well, they are all solids and not a block.
DXFOUT = the same thing as the first corruption pic above.
Message 12 of 13
drjohn
in reply to: drjohn
So I found a friend that had SC 2012, sent him my file.
He had no issues importing it. Looks just like the pic in cikho's post above.
So I asked him to save it as a SC file and I opened it in 2014 and all was well.  But that just ain't right. Smiley Frustrated
 Gotta be dwg file format.  Just gotta be. I'll find an ACAD 2014 or better and save in that DWG format and try again.
I'll let ya know.
Thanx much for the brainstorm.
DJ
Message 13 of 13
cikho
in reply to: drjohn
just look for the 2014 hotfixes and service packs around
Technology Administrators
