Showcase Forum
Welcome to Autodesk’s Showcase Forums. Share your knowledge, ask questions, and explore popular Showcase topics.
screw-nuts moves
4 REPLIES 4
oleg_inv
672 Views, 4 Replies
screw-nuts moves
Hallo!
Please help me to create an animation screw-nuts ...
I Can`t combine the two moving:
1. move nut along bolt axis and 2. nut rotation around bolt axis simultaneously
4 REPLIES 4
cikho
in reply to: oleg_inv
go to organizer.
select the bolt
create a group containing the bolt
now create another group containing the group created before.
animate the first group with the rotation
 and the second group with the sliding movement..
i did not test this, but this is how i animate folding doors and it works
_________________________________________________________
almost a showcase PRO user 😛
if you find my post useful, please give kudos or mark as solution 😄
cikho
in reply to: cikho
here is a quick example
check the organizer for the group reference
MarionLandry
in reply to: cikho
Thanks to you Cikho, I was able to record a video showing the steps.
Hope this helps.
I wish I had a better model for it.. oh well..
Marion
http://youtu.be/7yddjyGxBrQ
oleg_inv
in reply to: MarionLandry
It's great!!!!
Thank You cikho and thank you MarionLandry!!!!
Technology Administrators
