once again i'm having issues with shadows.. meh..
in particular shadow borders look "serrate" even with high quality 4096x4096, and in particular the higher the softness the higher and most spread the serrate effect is..
it depends mainly on the object position, for example on the floor i get acceptable shadow effects, but in other points of the models, the issue is almost impossible to resolve..
Solved by cikho. Go to Solution.
Yes. To me the same thing happened to me.
In models some great architecture, the problem is serious.
Hopefully in 2016 sowcase measures to correct this.
Greetings.
