Screencast Forum
Welcome to Autodesk’s Screencast Forums. Share your knowledge, ask questions, and explore popular Screencast topics.
Unsupported Operation Error only when using Screencast
1 REPLY 1
Gary.Barr
406 Views, 1 Reply
Hi guys,
I'm trying to record a Civil 3D screencast but keep running into an 'unsupported operation error'. This only happens when recording. If I'm not recording everything works fine.
All I am trying to do is access the model settings via the Toolspace so I can change the coordinate system. However as you can see I get the error and once I change the coordinate system I don't get the 'Geoloaction' toolbar appearing as it normally should do.
Any suggestions or should I just use OBS instead?
Tags (1)
1 REPLY 1
ram.mummidi
in reply to: Gary.Barr
Hi @Gary.Barr ,
Thank you for bringing this to our attention. We were able to reproduce this issue on our end. I will debug and look into this issue and we have opened a ticket on our end.
Thanks, --Ram
Ram Mummidi
Principal Engineer
