Hi. I am new to Screencast and I think it is a great tool. I created a test screencast which is private and attempted to download it with no success. I have tried FireFox, MS Edge, and Chrome just in case it was a browser issue. I am using the latest version of Screencast. Any ideas?
Solved by TooTallEd. Go to Solution.
Ok. I'm not sure why the screencast I attached to my original post isn't showing up or why I cannot update my own post since there are no replies. So i am attaching the screencast it to this reply and posting it here. http://autode.sk/2gXEa1z. I think it has something to do with the buttons being none responsive.
Ed
It's working here for me in Chrome.
Just so you know, this is what it should be doing.
Thank you for your response. Seeing your screencast helps and would normally make me believe its a pop-up blocker issue. So I have turned off all the pop-up blockers in both Chrome and IE and still no dice. Its aggravating when something seemingly so simple doesn't work.
FINALLY! I have finally linked this issue to an issue I have been having with switching between my Google accounts. I have worked around this issue by right-clicking and selecting open in a new tab. That work around works here too. So this is not an issue with Screencast!! Thanks for the feedback.
Thanks for the idea. I don't have the issue of switching between Google accounts on my work computer. So likely this issue is only with my PC and trying it on another PC will likely work. I will still try it though. I think this is an issue with my registry but I don't know how to fix it.
