Announcements
The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform Forum (Read Only)
Scaleform enables developers to leverage the power of the Adobe® Flash® tool set to create powerful user interface environments for video games.
Trying to build for Android
6 REPLIES 6
973 Views, 6 Replies
Cant for the life of me get an Android build to happen
have tried both 4.2 and 4.4, but neither want to work
am getting the following error from 4.2
Projects/Common/3rdParty.mk:153: recipe for target 'Obj/Android/3rdParty/expat-2.1.0/expat_config.h' failed
make: *** [Obj/Android/3rdParty/expat-2.1.0/expat_config.h] Error 1
anybody have any ideas??
6 REPLIES 6
forgot to mention, the above is happening on Windows
have tried build on Mac as well and are getting the following error messages
on 4.4
/Developer/Applications/Android/android-ndk/toolchains/arm-linux-androideabi-4.9: No such file or directory/arm-linux-androideabi-ar: Src/XML/XML_Expat.cpp
make: *** [Lib/Android/armeabi-v7a/Shipping_NoRTTI/libgfxexpat.a] Error 1
on 4.2
Unable to locate an executable at "/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/bin/javac" (-1)
make: *** [Integrations/Android/FxPlayerMobile_Shipping_NoRTTI/src/com/scaleform/FxPlayerMobile_Shipping_NoRTTI/Debug.class] Error 2
I've no idea what to do now. 2 different systems and neither of them will work
have tried the deployer on 4.2 (with no luck) and on 4.4 it won't open at all
on 4.4
on 4.2
finally managed to build in 4.2 (after a lot of hacking about), but still no joy with 4.4
still getting the error
adjm
adjm
Hi Guys,
Just to follow up here, there is a just about finalized patch over at the top of this thread that addresses all currently known issues for Android:
http://forums.autodesk.com/t5/scaleform-mobile-development/scaleform-4-4-mobile-sdk-android-deployer...
Once I get confirmation on the Mac OS X Deployer, we will be releasing an updating Android packages including all of the fixes.  Thanks again for your patience with this.
Jeremy
Scaleform Engineering
Hi Guys,
Jeremy
Hi,FiveForty.We ran into same error on gfx 4.2.would you mind to share your way to solve the error?
I solved the problem.We installed the 32 bit cygwin, then error fixed
