The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform Forum (Read Only)
Scaleform enables developers to leverage the power of the Adobe® Flash® tool set to create powerful user interface environments for video games.
SFCamera prevents Meshes from rendering on device
4 REPLIES 4
494 Views, 4 Replies
I'm having trouble with Scaleform 4.2 running on iOS devices.  All behaviour is perfectly normal in the Unity editor, but on device after loading a scene all Cameras only seem to render for a single frame and then no longer render at all.
After some investigation I've determined the following:
  • everything behaves normally on device when the app first loads into the default scene, with both SWFs and Meshes rendering as normal;
  • after calling Application.LoadScene or LoadSceneAsync all meshes render for a single frame before disappearing (this single-frame render happens again every time another scene loads);
  • this issue occurs whether any SWFs are loaded or not, pointing to SFCamera as the culprit (and the issue disappears if I disable or destroy the SFCamera script then load a new scene);
  • loading a SWF via SFMovie renders that movie normally, even while all meshes in the scene are not rendering;
  • I've verified that all Cameras in the scene remain active and enabled, and disabling/reenabling them when loading a new scene doesn't fix the problem;
Any clues as to what is going on?
4 REPLIES 4
I've discovered another interesting behaviour related to this issue.
If I stick an OnGUI() on any MonoBehaviour active in the scene, the problem disappears. This code makes me so sad:
void OnGUI()
	GUI.Button( new Rect(-100, -100, 0, 0), "");
 Problem solved!  Robot Sad
Tags (1)
I have run into this problem as well.  I also came up with an extremely stupid workaround.  I'd like to know the root cause of this problem too.
+1
Same issue. I usually have an empty GUIText or a transparent GUITexture 😞
+1.. workaround by creating an invisible gui component in an OnGUI() call.
