The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Scaleform Forum (Read Only)
Scaleform enables developers to leverage the power of the Adobe® Flash® tool set to create powerful user interface environments for video games.
Scaleform compile errors in XCode when using latest Unity (4.6.7f1)
3 REPLIES 3
946 Views, 3 Replies
Since upgrading to Unity 4.6.7f1, any Scaleform projects built for iOS will fail to compile in XCode, including the demo project.
The error is:
/Users/dave/Projects/Unity/Scaleform/Build/Build/Classes/Native/Bulk_Assembly-CSharp-firstpass_0.cpp:13397:105: No viable conversion from 'IntPtr_t' to 'intptr_t' (aka 'long')
It's referring to the _il2cpp_pinvoke_func line below. Are IntPtr_t and intptr_t the same thing? Is there a something I can do to work around the problem? Perhaps it's a Unity IL2CPP issue?
extern "C" IntPtr_t MovieDef_SF_GetFileURL_m266 (Object_t * __this /* static, unused */, IntPtr_t ___pMovieDef, IntPtr_t ___size, const MethodInfo* method)
	typedef intptr_t (DEFAULT_CALL *PInvokeFunc) (intptr_t, intptr_t);
	static PInvokeFunc _il2cpp_pinvoke_func;
	if (!_il2cpp_pinvoke_func)
		_il2cpp_pinvoke_func = (PInvokeFunc)SF_GetFileURL;
		if (_il2cpp_pinvoke_func == NULL)
			il2cpp_codegen_raise_exception(il2cpp_codegen_get_not_supported_exception("Unable to find method for p/invoke: 'SF_GetFileURL'"));
	// Marshaling of parameter '___pMovieDef' to native representation
	// Marshaling of parameter '___size' to native representation
	// Native function invocation and marshaling of return value back from native representation
	intptr_t _return_value = _il2cpp_pinvoke_func(reinterpret_cast<intptr_t>((___pMovieDef).___m_value_0), ___size);
	IntPtr_t __return_value_unmarshaled;
	(__return_value_unmarshaled).___m_value_0 = reinterpret_cast<void*>(_return_value);
	// Marshaling cleanup of parameter '___pMovieDef' native representation
	return __return_value_unmarshaled;
The error is:
3 REPLIES 3
It seems that this is an IL2CPP problem in 4.6.7. Unity are aware of it. Until it's fixed, 4.6.6 should work.
I encountered the same problem.
But it's fixed on Unity 4.6.7p2. Try it 🙂
Yep, all fixed now, thanks for the update!
