Hello, I created an easy model of a concrete structure in Autodesk Revit setting the beams analytical model in the same plane as the structural floor while adjusting the offset value of the beams
Then I uploaded the model to Autodesk Robot. I would like to make the beams work together with the slab, that is to receive some of the loads applied to the slab. The offsets were not transfered, but that is not the problem as I can set them manually. However I don't know how to "link" the beam the the slab securing an analytical connection. I would be grateful for any advice you can offer.
This will be done automatically via nodes of a mesh generated for the slab.
