Dears in Autodesk,
I hope this mail finds you well, This paper is allocated to show the outlines of a new method for optimizing structural members in the environment of structural analysis applications, this method assumes that all types of structural members whether it is linear, surface, or volumic must be modeled as a volumic member, this would require a substantial amount of extra processing. However, it might improve the model matching to reality, and led to the ability to check the part of the section that cannot be checked directly using the old method.
Since the article is relatively big and contains pictures, It was sent as a link.
https://onedrive.live.com/view.aspx?resid=65AA62048B3477F3%21265&id=documents
Best regards.
