When entering the values in the EC8 seismic analysis parameters window, let us use TAB to browse through parameters.
Right now, when you do this, you skip parameters in the window, and it is stressing and time consuming to change those parameters with the mouse.
I think it would be productive if after giving a value to ag, you could press TAB to change the behavior factor and not to give an OK.
