Scheduling analytical results from Robot in Revit
I have noted that when ones send your design model from Robot back to Revit with results it can't be scheduled. The "results explorer" works great to visually view results but still doesn't update the analytical results of each member, it has to be done manually. It seems like to analytical results are not connected to the properties of the analytical members. For example, this would especially be handy when one does column load-rundowns to simple extract the results through schedules of all columns at each level.
1 Comment
renan.jose
Did you find out how to do that ? I mean, how to fill Revit schedules with calculated values from Robot ? Thanks
