Save and Recall Diagrams/Maps Display Settings
A good feature would be to save the current diagrams/maps settings and recall them across projects.
An example is when I am exploring the results on a steel structure,  I display the moment diagrams and axial force maps as follows:
  1.  Clicking Results-Diagrams for Members-My Moment-Parameters-Differentiated-Filled-Text-Apply. (8 clicks)
  2. Then Results-Maps on Members-Fx-Parameters-Text-Scale-Automatic scale-Apply (8 clicks)
That is 16 clicks to get to the display options that I used all the time on every project. If there was a way I could save these settings and do something like clicking on 'Saved Displays'-'Fx Maps & My Diagrams'-Apply. This would only be three clicks and very useful and would allow us to build up groups of display options that will streamline workflows.
Hopefully this gets seen and wouldn't be too difficult for the team to code as well.
1 Comment
ArunNDinesh
@ismaeelm Once you set the results in the way you want (8+8 clicks). In the same window enter "new" panel number and press enter and open in new window. You will get similar display for new panel in new window. This is a work around to save your time or tedious task.
