ROBOT should improve its BIM level.
To be BIM, at least the elements that go in an axis should move when moving the lines of construction. Also when changing the height of stories should change the height of the columns just like happens in REVIT. That would be a BIM software.
2 Comments
Good morning davidartpp,
Robot already does all the things that you have posted as IDEA. Try to create a structure with grids and levels, then click over a gridline and try to change its properties.
Cheers
davidartpp
Thanks Stefano!
