Hi
I would like to see better interoperability between Revit & Robot. That would be a major selling point for a BIM platform. The ability to transfer between the 2 platforms id great, but more often then not there is a lot of work required to make the design model ready for analysis.
Analytical columns/beams that "are slightly off axis" when the Revit model is correct is a major issue. Why is it even possible for these elements have an analytical line that can vary from the element itself?
If this transition is done seamlessly and worked like it should, it would make Robot the number 1 design software in the market solely based on the success of Revit. There really is no time in the modern market to model a structure twice!
