Currently the design output of Beam results does not show the required transversal reinforcement area. It only shows the design info which is mainly defined by the user before the calculation. It expects user to set the bar diameter and number of legs on the calculation parameters menu. However, most of the time user can’t know the number of legs and the bar diameter beforehand. Now the resulting table shows Provided Transversal Reinforcement not the Required value.
It would be great to see an additional column on the Results Table which shows the required trans. reinf. area / spacing (cm2/cm).
It would be also great to get these values (num.legs, str.diameter, req. ttrans. reinf.) directly from the API in the name of efficiency. (not by dumping the table to excel)
