Panel cut table
Panel cut table
Hi
It would be very helpfull to be able to get panel cuts in table and the ability to copy a panel cut. For instance if you have different models with the same geometry it would be fast if you where able to copy panel cuts into a model.
And also to see the results from more than 14 panel cuts at a time.
Also it would help a lot if you could get more than one result at a time. If you need to check both top and bottom envelope.
5 Comments
I second the suggestion in the post above. If a panel cut input table be provided for example with
1. start - end coordinates
2. type of output  - mxx/complex mxx etc
3. type of smoothening
4. cut name
etc in a table.
We end up comparing panel cuts acorss various iterations of a fairly large model across many locations and it may help just copying pasting the cut definitons across mulitple robot files. It takes up quite a bit of time to draw all the cuts again. Furthermore it will be nice to sort panel cuts by name in robot .Just a wish. Thank you
Regards
philip.s
Status changed to: Gathering Support
prior status deleted, setting to default
SerhanB
Exporting panel cuts info to an external file (which can be imported back to another model) would be a very handy feature!
jakobbruhl
Please! This would be very helpful in the design of reinforced concrete structures. The data from the panel cuts can be used to determine bar cut-off locations. Without the data being provided in a table form, there is wasted time (and potential error introduced) in reading and recording specific points from the panel cut using the "diagram analysis" feature.
MarkNguyen...
Do you already have an answer to this problem?
