Node selection
Node selection
  When we select a node by indicating its number, it is marked with a green color spot in the structure but if the structure is a little more than simlpe it's difficult for the user to see where it is... It should be marked by a different (more clear) way, for instance the node could be enclosed in a small circle in order to be visible.
4 Comments
Rafacascudo
on display options , mark " display atributes only for seleceted elements " and then click to show node number.you will easily find it
Tuctas
  I didn't notice any big difference in the visibility by choosing this option..
Mirko.Jurcevic
I don't understand why there is no option for changing the node shape and size.
Those little dots that nobody can't see easily are not a good solution.
A lot of people complain about this.
philip.s
Status changed to: Gathering Support
prior status deleted, setting to default
