Imporvement for obtaining internal forces using Solid Cuts in volumetric analysis
Dear RSA team,
I have a suggestion regarding the improvement of Solid Cuts function using volumetric analysis. I am currently working on a tunnel structure modeled using solids, and I want to extract internal forces for specific cut between two particular points. However, when I use Solid Cuts to define a cut between two points parallel to a certain axis the infinate plane is being created which cuts throughout the whole structure. Consequently, when I try to obtain internal forces for a specific region using internal forces in the table function, the integration is only performed for the whole cut. It would be very convenient if the RSA had a function to obtain internal forces for a specific region of the cut when volumetric analysis is considered. Thank you!
Karolis Sakalauskas
