implement the AISC 360-10 code for steel connections
Hi.
I see someone had posted this in 2016 and I would like to support this request. We do calculations on drilling structure in accordance with the API Spec 4F (API = American Petroleum Institute). API released an addendum suggesting that connections using tubular sections shall be checked against the requirements of AISC360-10.
Doing this manually is just not realistic. considering the multiple beam and load cases.
I tried migrating a model from Robot to Revit - it doens't work.
So our only choice at the moment is doing it manually or subscribing to other software. Since you already have plenty of EN connection code in Robot, why not implementing AISC? (since you also already have AISC 360-05 + 360-10 steel members code checks)...
Your earliest response will be much appreciatedas we're currently looking at solution in that regard
thanks in advance
Stephane Niemczyk
4 Comments
stef.niemczyk
Autodesk Team,
gentle follow up on this.
thanks in advance & best regards
stephane niemczyk
stef.niemczyk
Autodesk Team
no response so far??
pawelpiechnik
Stef,
Have you checked on the steel connections AISC code design in Revit? Would be great to hear your feedback on that. https://www.youtube.com/watch?v=h2X3u-rCxP8
We have also worked with our partner IDEA Statica bringing to Robot modern connection design capabiliies https://www.ideastatica.com/resource/Content/02_Steel/Videos/Tutorials/Link%20toAutodesk%20Robot.htm
regards
Pawel
andres_urrutia
please! we need AISC360 connections!
