IFC EXPORT
IFC EXPORT
I urge Autodesk to implement IFC export in Robot Structural Analysis in order to enhance the BIM environment .
6 Comments
cogeciggr
I agree jad_160. I cannot understand why in the year 2021 this trivial feature is still not available. All other calculation software (SCIA, RFEM, etc...) already have (and for a long time)
mgirardH6HGP
And the IFC export must be with GUID to keep the properties on the model.
jad_160
I usually export it to advance steel if it is a steel model than re-export it as ifc file . it is bizarre that we're in 2022 and robot 2023 version still doesn't have this feature , while all the other structural analysis softwares in the market have it and are widely developing their features .
LeeCastro
Excelente iniciativa.  Se ainda puder editar faça a solicitação de importar/exportar.  A bidirecionalidade é importante.
mgirardH6HGP
Obrigado pelo vosso tempo.
Se o meu pedido já pudesse ser processado, isso seria ótimo. Penso que, na direção oposta (importação), seria demasiado complicado de processar. Os IFCs são elementos de volume, enquanto o Robot processa elementos de barra. Já é muito complicado utilizar uma base DWG 2D como base de trabalho no Robot!
Thank you for your time.
If my request could already be processed, that would be great. I think that in the opposite direction (import), it will be too complicated to process. IFCs are volume elements, whereas Robot deals with bar elements. It's already very complicated to use a 2D DWG base as a working base in Robot!
excelente ideia ! por favor exportem em ifc
