How to get the value of the line load on a slab due to structural walls on it using ROBOT?
How to get the value of the line load on slab due to structural walls on it using AUTODESK ROBOT STRUCTURAL ANALYSIS PRO?
I need to find the reaction at the base of the structural wall which is supported only by the slab under.
The load from the wall is transfered to the slab as a line load, and the value is required to design the slab.
Thank you for your time!!
1 Comment
Romanich
