Demonstration Videos
Good evening,
We are in desparate need of good demonstration vidoes for the current version of Robot.  Make no mistake, the lack of videos is costing not only time but valuable fees.  We sometimes forget that whilst it may be fun using a piece of software, for many/most users the ultimate aim is to design something and get it built.  We unfortunately do not have unlimited time and money to spend trying to work out how to use a piece of software.
I am aware that product supprot prepare short videos to answer specific questions.  Where are these videos?  Where is the library that I can go to and scroll through previous videos?
I am spending hours trying to get certain functions to work with no success.
Thank you
Chris
6 Comments
Μηχανικος
I am no user of RSA but i am interested in purchasing the software however i am very skeptical after realising that there are no proper tutorials available. What scares me the most is that this is happening for about 3 years now which clearly shows that Autodesk is not planning to publish any videos.
Even users dont seem to care, no one is supporting your post. Maybe this is a software for really advance users.
chrismcc
Hello Μηχανικος,
Autodesk have just started Robot webinars, so that is positive.  There is a very active forum with support from Autodesk and ideas, solutions and suggestions from several users - so that is all positive.
There are a few things which I see as fundamental to allow you to make better use of the software to avoid some of the pitfalls which are not at all obvious in the documentation.
New ideas are being added to the Ideas list so hopefully some of these will be implemented.
Buy the software, but I suggest that you only use the forum for support.
Good luck
Chris
Μηχανικος
Hello Chris, where exactly can i find those webnars?
Why do you suggect i only use th forum for support? what about videos in youtube?
Regards
Evripidis
Μηχανικος
I found the webinar and i have also registered for upcoming ones.
pawelpiechnik
Status changed to: Accepted
pawelpiechnik
https://knowledge.autodesk.com/support/robot-structural-analysis-products/learn/caas/qsguides/robot-...
Similarly to the recently created Quick Start Guides for Revit and AutoCAD LTRobot Structural Analysis now has its own video-based Quick Start Guide for engaging and efficient onboarding to Structural Analysis and Design workflows. The quick start guide was shaped by the opinions and guidance provided in the survey we ran a year ago that asked for your feedback on what a modern Getting Started Guide should look like and we also wanted to replicate a real-life analysis and design scenario for a typical structural project. The scope includes Modeling, Analysis, Design, Documentation and BIM interoperability stages presented in 50+ explanatory videos. There are two tracks covered respectively for Structural Steel and Concrete workflows.
