Hello
I am aware of How to create and design a user defined thin walled section in Robot Structural Analysis (autodesk.c... guide but we need an easier workflow. Those steps should be reduced, and we should be able to create thin walled sections like regular sections.
When we changed dimensions from the section database (main section view) the values at the right panel should be calculated automatically. (It's like running section definition module in the background. You can put a calculate button after changing dimensions of the section then it will be preventing unnecessary calculations and provide the option of calculate on demand)
All mentioned features are already included in Robot but developers should connect those modules in order to work with a seamless workflow.
