can't show the entire structure in the Robot
I am working on the structural analysis for the project. However, when I convert the model from Revit into Robot, it can only show part of the structure. What is the problem of it? How can I fix it ?  The attached file is the model that I am working on.
1 Comment
okapawal
Hi @gl446
If you have questions, you better post it on the Forum, not on the Idea Station.
https://forums.autodesk.com/t5/robot-structural-analysis-forum/bd-p/351
The answer to your question is simple.  Keep in mind that Analytical Model is transferred to Robot.
You need to check "Structural" for architectural floors.  And for all elements that you want to transfer check "Enable Analytical Model"
Right now your model is incomplete
