Show only
Search instead for
Hello, Hashim Khalil. Can you explain how it might work? What is the difference SAFE from the Robot slab settings "Parameters of foundation elasticity" ? Thank you.
in safe program you can enter column and wall loads and it gives you accurate results with punching shear also . but in robot we enter loads by nodes . so results will be different . i said that it is better to have a template as we have template for beams and walls .... etc
