WishList: Selection
WishList: Selection
Romanich
Mentor Mentor
Message 1 of 8
WishList: Selection
Romanich
Can you add to WishList ability to select only in the current view in the Selection dialog?
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (7)
Message 2 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Roman,
the requested selection effect can be obtained using selection by window in the current view and then using "common part" of this  selection with selection by some section - like HSRO 14x0.312 section on the screen capture below:
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 3 of 8
Romanich
Hi Pawel,
Thank you for your reply, but I meant something else. Please, see this video.
Roman Zhelezniak
Message 4 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
Hi Roman,
when I have written "using selection by window in the current view" I meant the new window with part of the structure - as in this video.
Pawel Pulak
Message 5 of 8
Romanich
Yes, but IMHO, my wish can be like a timesaver, because in this case user make a little less mouse clicks 😉 For example, checkbox with on/off In curent view only.
Roman Zhelezniak
Message 6 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
I understand your point but it would result in additional check-box in the selection window making it even more sophisticated.
Pawel Pulak
Message 7 of 8
Pawel.Pulak
Autodesk Support
Autodesk Support
Feature idea to obtain it in more direct way registered by Rafal:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Selection-in-New-Window/idi-p/3744561
Pawel Pulak
Message 8 of 8
Romanich
Thank you, already voted for that 🙂
Roman Zhelezniak
