- Mute
- Permalink
- Report
i have some queries on the wind simulation tool in rsa.
If i calculated a uniform wind pressure to eurocodes outside of the rsa program of say 1.35kN/m2 to be applied to the building, this i have then entered this pressure value into the wind simulation model in robot, if i assume a constant wind profile veloicity factor of 1.0 throughout the height of the building and the wind tunnel height (2 x building height) would this give me a constant pressure applied of 1.35kN/m2 on the face of the building? As the pressure varies in my model?
How does the velocity factor actually work, does it multiply the applied wind pressure by the velocity factor in the wind profile throughout the height of the building, because when i increase this it seems to give less moment applied on my walls not increased?
Also, if the wind pressure is applied over the face of the building by hand calculation based on eurocode wind pressure calculation, when the same pressure is applied in rsa wind simulation, the wind simulation gives me significantly less moments on my foundations, is there a reason for this?
thanks,
Simon.
