Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
WIND LOAD Simulation - generate wind load cases
Is it possible to re-run the same wind load cases? I notice that always generate new load cases , which is a bit of awkward since the combination load cases already call the existing ones. Is there any option to avoid having to change the load cases?
Miguel
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
If you already generated load case with actual loads from wind simulation they are stored in the rtd file and there is no need to run wind simulation again.
If you want to change the parameters then try7 the following:
1. Delete all loads from the wind load case that you already have
2. Run wind simulation which will create new load case
3. On the edit tab of the load table select all newly created loads and using fill special change their load case from the newly created one to the already existing old wind load case (watch: Build Your Robot Structural Analysis IQ! - Tips and tricks in Robot at approx. the 21st minute)
4. Delete the new wind load case.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Hi @Artur.Kosakowski
The fill special command does not seem to work in the load table?
Artur.Kosakowski
Autodesk Support
Autodesk Support
HI @Anonymous
It works and I have been using it for many models over last years :-). Mind that as the table has got variable data in its field it can only be used for Case and List fields.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Thanks @Artur.Kosakowski
I just realised that I forgot to run the analysis after generating the wind loads!
It works now!
