will the program correct if my designed/beam size is unnecessarily big for the
ltaha
ltaha
will the program correct if my designed column/beam size is unnecessarily big for the given loads ?
Rafacascudo
On steel design , yes , if you choose Robot to design the choosen bar.
It will choose the section that better suits the criteria (weight, height,etc) among the portfolio of sections choosen by the user.
Rafael Medeiros
ltaha
okayy..so for RC structures im all by my self
mustafahesenow
Hi @ltaha
For beam it can be If you control this option shown in the picture:
For Columns It was before available but since they start to use the extension for changing column dimensions it became not available.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
