When to use lumped and when to use consistent mass matrix?
Artur.Kosakowski
Autodesk Support Autodesk Support
Artur.Kosakowski
Autodesk Support
Autodesk Support
Originally posted by  @Anonymous in this topic.
Moreover, can you tell me when to use lumped and when to use consistent mass matrix?
Artur Kosakowski
Thank you for your assistance. I can not accept this as a solution as i am not the author of this post.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
The consistent one us recommended for a model where you have no nodes along bar elements and your aim is to find out the exact values of eigenfrequencies (e.g. to avoid a resonance) whereas the lumped for model with many nodes (e.g. multi-story building and seismic analysis) where you need to reach 90% participating mass and the exact shape of vibrations is a secondary objective.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
I am designing a curved roof structure supported on the main station structure. I have used lumped mass for dynamic behavior calculation. Could you please advise on which nodes will the lumped mass be concentrated? Will it be at each node intersection?
The model is shown below
Thank you,
Mayank
